I can transfer a file in GUI, transferring using a script returns as permission denied
I have created an SSIS package with an execute process task that runs WinSCP. I am running Visual Studio 2012 as admin.
The script is very straightforward where it is opening a session and then navigates to a directory to get a file. I have complete access to the directory upon checking in the GUI. However running the package encounters a permission denied error and the task fails. I have read all FAQs but still Im stuck.
I have attached both logs. Thank you in advance.[/img]
Description: Log from the script
Description: Log From GUI session
Re: I can transfer a file in GUI, transferring using a script returns as permission denied
In the GUI, you go to /INTERFACES/FUL/ARCH, while in the script you go to /root/INTERFACES/FUL/ARCH. So I suppose, you just need to remove the /root from the path.
Also, you urgently need to upgrade.
