Line ending
agough
Line ending
When using the internal editor in winscp it screws up my file line endings. i have dos files on my linux server. when I edit them through winscp it seem to chenage the line endings, which is a problem for some of the processing am doing on the files. Is there any way to preeve the line endings? I haven't stuck a file into a hex editoryet to see hat it does but I assume it is either stripping the \r or the \n when I vi the file it showsa file format of [noeol] a :set ff=dos fixes the problem.
Anyone got any ideas?
Re: Line ending
Either use external editor (and force binary transfer mode) or configure DOS line endings on Environment tab of Login dialog.
