SFTP script error: Opening session using command-line parameter in scripting is deprecated
mfrank
I am trying to do a simple file transfer to an SFTP site using a .bat file to call WinSCP.com, passing it a basic script file. This is how all the examples I can find on the internet seem to show how to do things. If I manually type the open/put statements into the CMD window, everything works great, but when I try to run the .bat file, I get the error:
"Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead".
The .bat file simply contains:
Winscp.com /script = SFTPTest.txt
The SFTPTest.txt file contains:
# Connect to SFTP site
open sftp://login:password@hostsite
# Upload the file to current working directory
put Testfile.TXT
# Disconnect
close
# Exit WinSCP
Any ideas how to get this working? My hope is to be able to schedule the .bat file to run daily to copy the file to the SFTP site.
endeekay
Perhaps try this in your batch file:
WinSCP.exe /console /script=SFTPTest.txt
And place the bat file in your WinSCP folder where the WinSCP.exe file is located.
Re: That did it!
It has nothing to do with the /console parameter, as that's implicit with winscp.com you were using.
The problem was the spaces around the =.
This is the correct syntax: winscp.com /script=SFTPTest.txt
