searching and symlinks : stuck in a loop
smitty123
Canada
using the search function (find files) , it gets stuck in an endless loop adding the path to the search path in an infinite loop, like the picture shows, notice the path at bottom of the window.
it never finishes the search.
winscpp 5.82 beta (b6284)
Re: searching and symlinks : stuck in a loop
smitty123
Canada
here are the logs
all i did was use find files for something in /sys and it got caught in a loop at
2016-05-16 16:45:38.513 Listing directory "/sys/bus/i2c/devices/i2c-0".
  • logs.zip (166.69 KB, Private file)
Thanks for the log.
I can see that in the i2c-0 folder, there's a device symlink to ../../mv64xxx_i2c.0. What is the mv64xxx_i2c.0? Is a symlink again? To i2c-0 or where?
smitty123
Canada
Thanks for the log.
looking in /sys/devices/platform/mv64xxx_i2c.0/i2c-0 i see what's in image i2c-0.png
and a symlink named "device" no "s" and that just points to ../../mv64xxx_i2c.0
aka /sys/devices/platform/mv64xxx_i2c.0 in absolute path. a parent folder.
