Error when I open a session
BlackAlpha
Reunion Island
I want to connect to a SFTP to upload a file with C# and WinScp but i'm having a problem, i got this error ah the "session.open()" line :
Connection has been unexpectedly closed. Server sent command exit status 0.
My code is :
try
                var sessionsOptions = new SessionOptions
                    Protocol = Protocol.Sftp,
                    HostName = Settings.Default.p_credHost,
                    UserName = Settings.Default.p_credName,
                    Password = Settings.Default.p_credPass,
                    PortNumber = 22,
                    GiveUpSecurityAndAcceptAnySshHostKey = true
                using (var session = new Session())
                    session.Open(sessionsOptions);
                    var transferOptions = new TransferOptions {TransferMode = TransferMode.Binary};
                    session.PutFiles(localFile, string.Concat("/", newFile), true, transferOptions);
            catch (SessionException error)
                MessageBox.Show(string.Concat("FTP Error : ", error.Message));
Even if I set an SSH key, I still get the same error, do you have an idea why ?
Re: Error when I open a session
Are you able to connect with any (even GUI) SFTP/SSH client?
