Use bigger font in Options dialog on high resolution desktop
Re: Use bigger font in Options dialog on high resolution desktop
WinSCP should use the same font size as the rest of the system.
Please post a screenshot showing the dialog and some system window.
Make sure you are using the latest version of WinSCP (ideally the 5.8.2 beta).
Re: WInScp small screen
The screenshot does not show anything.
But I you probably have problems because of lack of per-monitor DPI support in WinSCP.
I'm working on this. Once I have anything to test, I'll contact you on your email address.
Though, if you have a single monitor only, Windows restart should help.
