WinSCP – Not supported Mainframe server – Bug #49
velsitech
As part of our development, we are trying to use WinSCP component to download the file from Mainframe server.
The same issue already raised under bug#49. Also, I have some there might be some settings for supporting Mainframe servers. Could you please share, what's the process need to be followed?
Regards,
Vels
Re: WINSCP - Not supported MAINFRAME SERVER - BUG #49
What protocol? SFTP or FTP?
Try 5.8.2 beta, it works slightly better with some non-standard servers.
MBRITO9
WINSCP vs MVF/MAINFRAME
WinSCP cannot change directory / dataset (internal CWD command) on IBM mainframe FTP server. Somehow it is not handling the dataset name properly – the name is doubled, e.g.:
Retrieving directory listing...
CWD /'USER34.'/'USER34.'/
550 CWD cmd failed : EDC5129I No such file or directory.
Anu clue?
Re: WINSCP vs MVF/MAINFRAME
We need an access to such server to resolve this. Can we have a test account on your server?
