Writing a script in a batch file to fetch files from SSH
viki lingeria
Hi ,
I am trying to write a script in a batch file to fetch the files from SSH server.
Have written the following code. But it does not seem to get the files from the server to my local machine.
Can you please tell me what could be going wrong?
Code:
# Automatically answer all prompts negativelly not to stall
# the script on errors
option batch on
# Disable overwrite confirmations that conflict with previous
# Connect
open gstar:gstar@3.49.4.80
# Change remote directory
cd home/data/fs/gstar/25_07_2005
# Force binary mode transfer
# Download file to local directory d:\
get gstar_currency.xml d:\
# Disconnect
close
# Exit WinSCP
Where : gstar is the username and the password.
Your assistance would be highly appreciated.
Regards
Viki Lingeria
Re: Writing a script in a batch file to fetch files from SSH
And what does it do?
I run the batch file & it gets executed with out any error. Pasting the output file here
C:\># Automatically answer all prompts negativelly not to stall
C:\># the script on errors
C:\>option batch on
C:\># Disable overwrite confirmations that conflict with previous
C:\>option confirm off
C:\># Connect
C:\>open gstar:gstar@3.49.4.80
C:\># Change remote directory
C:\>cd home/data/fs/gstar/25_07_2005
C:\># Force binary mode transfer
C:\># Download file to local directory d:\
C:\>get gstar_currency.xml d:\
C:\># Disconnect
C:\>close
C:\># Exit WinSCP
C:\>exit
Frankly I am not sure where is the script going wrong. Is something missing in the script.
Regards
Viki Lingeria
I have no idea what you are doing. You need to execute the script via WinSCP, not directly (or whatever you are doing)!
viki lingeria
Hi Martin,
I am writing the script in a batch file. i.e. in a .bat file extenstion.
Do I have to write the script some where in WinSCP?
Kinldy reply. I am aware my question might have sound stupid. But I am new to WinSCP and I desperately need to transfer files from one server to another.
Please assist.
Regards
Viki Lingeria.
You need to pass it to WinSCP using /script parameter. Please read documentation .
