overwrite read-only files
no matter
Which option/switch will force WinSCP overwrite without prompts local NTFS/FAT files, having "Read-Only" attribute?
P.S.
Do not push me to "Documentation", if you do not want to answer the question.
Re: overwrite read-only files
There's no such option in GUI.
If you mean scripting, use batch confirm off (what is the default for scripts).
Martin,
Many thanks for your response. I am using scripting in this task, have "batch confirm" turned "off" and it works as expected, until someone put "Read-Only" file into folder, involved in synchronization. "PreserveReadOnly" is not applicable there, because local folder receiving files from remote can be updated directly by local users with files already have "Read-Only" attribute. Now I run script to remove "Read-Only" attributes before running WinSCP script. This resolves the issue but folders tree is huge and re-setting attributes take time. I went through documentation but did not find option/switch can be used to resolve the issue by WinSCP itself. If such option/switch exists, please point me to right place in documentation.
Regards,
Mark
Martin,
Sure, see attached. The log produced after setting Read-Only attribute to ".banner" file.
C:\tmp\1>attrib C:\tmp\2\.banner
A R C:\tmp\2\.banner
Regards,
Mark
  • winscp_overwrite_local_readonly_failed.7z (3.11 KB, Private file)
Description: unable to overwrite read-only file log
OK, I've assumed that by "prompt" you mean a confirmation prompt, that WinSCP displays with SFTP protocol, before overwriting a read-only file.
But you obviously mean an error message that you get with FTP. As with FTP protocol, overwriting read-only files is not implemented.
So there's no way currently, sorry.
... not implemented ...
Thank you for your response. This is what I wanted to be sure.
