Connection timed out when using tunneling
Hi, I'm using Windows 7. I am trying to create a connection to one server and configure a tunnel to another server. The connection to the first server, without the tunnel, works alright.
The second server is up and running, in fact I am logged in it at this very moment via SSH tunnel from a Linux computer right next to my Windows one.
The SSH ports in both servers are 22 (both are correct), however, everytime I try to connect, I get a message saying:
Opening tunnel...
Searching for host...
Network error: Connection to "..." timed out.
There is no firewall in my Windows, in fact, using SSH Secure Shell for Windows, it works (but not on WinSCP). I am absolutely sure that all the ports, addresses and usernames are correct. What could this be? I've tried multiple Local tunnel ports, including the automatic choice.
Thank you very much,
Chicoscience
Re: Connection timed out when using tunneling
Plus a log from your SSH client.
