Starting with dot folders
Re: Starting with dot folders
Just enable Show hidden files preference option:
https://winscp.net/eng/docs/ui_pref_panels
Though with FTP protocol, the problem can also be that WinSCP uses MLSD command, while the "other FTP program" is using an obsolete LIST command. Some FTP servers do no include hidden files to the MLST command listing.
See https://winscp.net/eng/docs/ui_file_panel#hidden_files
faruxx
Turkey
But these are foldes. not files.
When check "show hidden files" checkbox i can see my folders. But i saw my local hidden files too.
Sorry, I do not understand this part. What do you mean?
faruxx
Turkey
I see my local hidden files and folders too.
i want to see only remote side hidden files and hidden folders.
