How to Upload and Download specific directory.
elecboy
Puerto Rico
I have been killing myself trying to download or upload a file to a specific folder, here is my command:
For Get I will like it to go to a remote folder called "download" and put everything in "d:\" in my local machine :
"get -neweronly -preservetime /* d:\"
For Put I will like to go to a remote folder called "upload" and put everything in "U:\Docs" in my local machine:
"put -neweronly u:\* /"
Thanks!
Re: How to Upload and Download specific directory.
"get -neweronly -preservetime /download/* d:\"
"put -neweronly u:\Docs\* /upload/"
elecboy
Puerto Rico
prikryl I have now a problem, I can download everything if it is not inside a folder, this is the command I am using:
"get -neweronly -preservetime /Download/* d:\"
They created a Folder called "Encounter" inside /Download/ so when WinSCP tries to download that folder I get and error, this is what I see in the logs:
2016-04-27 09:50:51.278 File: '/Download/Encounter' [2016-04-27T13:27:44.000Z] [0]
* 2016-04-27 09:50:51.278 (EOSError) System Error. Code: 3.
* 2016-04-27 09:50:51.278 The system cannot find the path specified
. 2016-04-27 09:50:51.278 Asking user:
. 2016-04-27 09:50:51.278 Error creating folder 'd:\Encounter'. ("System Error. Code: 3.
. 2016-04-27 09:50:51.278 The system cannot find the path specified")
< 2016-04-27 09:50:51.278 Script: Error creating folder 'd:\Encounter'.
Thanks you!
Do you mean that you can download a file from /Download/ (say /Download/file.txt) to D:\file.txt, but you cannot "download" a directory /Download/Encounter to D:\Encounter?
Please attach a full log file showing that (using the latest version of WinSCP).
Yes you are correct!
I include WinSCP Log.
  • winscp.txt (4.31 KB, Private file)
OK, but can you attach a log showing a successful download of the file, but a failed download of the directory, in the same session?
