Command line: allow on forwarding
Tomato251
Hi everbody,
Is it possible to set enable the option "Allow on Forwarding" in a command line?
Thanks for your help.
Ludovic.
I try this command, but i feel that ingores "/rawsettings TryAgent=1 AgentFwd=1"
WinSCP.exe <user>@<host> /rawsettings TryAgent=1 AgentFwd=1
Re: Command line: allow on forwarding
Your syntax is correct.
Hi prikryl,
I use this command
WinSCP.exe j499708%40be16dns%3ASSH%3Aj499708@ssh.bastion.inetpsa.com /rawsettings TryAgent=1 AgentFwd=1 /log="C:\winscp2.log" /loglevel=2
  • winscp2.log (105.47 KB, Private file)
Description: log
Hi everybody,
I found a work around, but that need a manual action:
- Select "allow agent forwarding" in Authentification
- click "Set defaults" in Stored sessions
I think with "/rawsettings TryAgent=1 AgentFwd=1" that will easier for end user.
thank you for you help, have a nice day.
Ludovic.
You are using WinSCP 4.1.8, which is over 7 years old and does not support the the /rawsettings. You urgently need to upgrade.
Hi Prikryl,
Yes, you're totaly right...
FYI, I'm in great company, I can't upgrade all WinSCP. I'm going to use a work around by updating the registry in my JAVA program:
reg add "HKCU\Software\Martin Prikryl\WinSCP 2\Sessions\Default%20Settings" /v AgentFwd /t REG_DWORD /d "1" /f
Thanks you for you help.
Ludovic
