Verify Checksum before deleting files ...
othmane
Paris
I found 2 scripts in the powershell examples page , I am using the first to download and delete files
the second script compare local file with remote file checksum
my objectif is to verify checksum before deleting files from remote directories.
any idea about how to include the checksum verification inside the first script ?
script 1 :
fore more details (I replaced synchronize with get function) : https://winscp.net/eng/docs/library_example_delete_after_successful_download
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        Protocol = [WinSCP.Protocol]::ftp
        FtpSecure = [WinSCP.FtpSecure]::Implicit
        HostName = "xxxx"
        UserName = "xxxx"
        Password = "xxxxx"
        PortNumber = "990"
        FtpMode = "Passive"
        TlsHostCertificateFingerprint = "xxxxxx"
    $session.SessionLogPath = "x:\xxxx.log"
    try
        # Connect
        # Download files
        $transferOptions.FileMask = "*"
        $transferOptions.PreserveTimestamp = $true
        $transferResult = $session.GetFiles("/","x:\xxxx", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host ("Download of {0} succeeded" -f $transfer.FileName)
           #$removalResult = $session.RemoveFiles($session.EscapeFileMask($transfer.FileName))
            #if ($removalResult.IsSuccess)
                    #Write-Host ("Removing of file {0} succeeded" -f
                        #$transfer.FileName)
                #else
                    #Write-Host ("Removing of file {0} failed" -f
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
script 2 :
fore more details : https://winscp.net/eng/docs/library_example_verify_file_checksum
param (
    # Use Generate URL function to obtain a value for -sessionUrl parameter.
    $sessionUrl = "sftp://user:mypassword;fingerprint=ssh-rsa-xx-xx-xx@example.com/",
    [Parameter(Mandatory)]
    $localPath,
    $remotePath,
    [Switch]
    $pause = $False
try
    Write-Host $localPath
    # Calculate local file checksum
    $sha1 = [System.Security.Cryptography.SHA1]::Create()
    $localStream = [System.IO.File]::OpenRead($localPath)
    $localChecksum = [System.BitConverter]::ToString($sha1.ComputeHash($localStream))
    Write-Host $localChecksum
    $sessionOptions.ParseUrl($sessionUrl)
    try
        # Connect
        Write-Host $remotePath
        # Calculate remote file checksum
        $remoteChecksum = [System.BitConverter]::ToString($session.CalculateFileChecksum("sha-1", $remotePath))
        Write-Host $remoteChecksum
    finally
        $session.Dispose()
    # Compare cheksums
    if ($localChecksum -eq $remoteChecksum)
        Write-Host "Match"
        $result = 0
    else
        Write-Host "Does NOT match"
        $result = 1
catch [Exception]
    $result = 1
# Pause if -pause switch was used
if ($pause)
exit $result
Reply with quote E-mail
Re: Verify Checksum before deleting files ...
So just move the CalculateFileChecksum and ComputeHash calls before the RemoveFiles call. And compare the results before actually calling the RemoveFiles.
