keep alive
huydang
keep alive
I try to use script to automate file transfer to hosted server, but it always get disconnected and reconnected all the times.
But if I use GUI, then the transfer is completed successfully
I check the log file and it shows below
2016-03-31 09:44:37.411 Session upkeep
2016-03-31 09:44:37.411 Sending dummy command to keep session alive.
Would you know how I can do that in scripting?
I would attached here
1/ my batch and scripting file for transferring (transfer got disconnected)
2/ log file for GUI transfer (completed transfer)
Thanks all for helping!
Cheers,
Huy
Re: keep alive
huydang
Thanks for your help!
I am ok with the setup now and it's working
But the log file getting big - is it only for debugging purpose and we should remove it in production environment?
Winscp.com /console /log=inspection.log /passive=on /script=transferscript.txt
Is it a workaround for this /log=inspection.log? We still want to keep a log file in case it stops working and we know what it is
