Site Location profiles are shared when only port of location differs
ChristianL
Munich
When I have multiple sites (sessions) where host and user name are the same but the port is a different, the bookmarks and "Site Location profiles" got shared.
The Port should be considered too when keeping site location profiles apart. Or is this a feature of "Clone to new Site..."? Anyway, I deleted the clone and added a new site manually, ending up in the same problem.
WinSCP v5.7.7
Thanks for your great work :D
Re: Site Location profiles are shared when only port of location differs
Thanks for your post.
This request has been added to the tracker:
https://winscp.net/tracker/1411
ChristianL
Munich
Hi Martin,
works as expected with the dev version. Thank you for your fast bugfix.
One thing I noticed:
All "Site Location profiles" got lost when using the development version. A migration from the old to the new storing system of location profiles during installation or after first run would be nice to have. Or an information where these settings are stored if they could be managed manually with a text editor or by regedit would help too.
Thank you very much.
Christian
Only the locations for sites with a non-standard port should be lost.
Go to HKEY_CURRENT_USER\SOFTWARE\Martin Prikryl\WinSCP 2\Configuration\Bookmarks\Remote (and \Local and other sukkeys) and rename the keys user@host to user@host:port for the sites with a non-standard port.
