SSL error when running update in Beta 5.8.2 (build 6284)
dcchriest@...
When trying to run the update feature in Beta 5.8.2 (build 6284) I now receive a SSL handshake error. The error states that the SSL handshake failed.
Re: SSL error when running update in Beta 5.8.2 (build 6284)
So did it work before? With what version?
Please attach a full log file from both versions for a comparison.
dchriest@...
I had version 5.7.6 installed previously. Attached it the log from the current version (53.8.2) since the beta installed over the previous installation.
dcchriest@...
So for the delay in my response - we were testing on our end and have determined that the SSL error was caused by new internal content filter software used by my company and not the beta version of WinSCP.
