Don't quite understand how to write get with - delete in powershell
saporter
Hello!
I've looked at some examples for how to delete a file after it is downloaded, using get -delete, but I don't quite understand how to write this in powershell. Using winscp 5.7.6, and powershell 3, I'm trying to sftp to a Linux server and download a file, and delete the file after it has downloaded. I can download the file but I don't know how to delete it from the server afterward. Here is my code:
# connect
# download files
$transferResult = $session.GetFiles("/directory/XDOWNLOADS/fileA", "c:\windowsdirectory\fileA", $False, $transferOptions)
# Disconnect
$session.Dispose()
saporter
Re: Don't quite understand how to write get with - delete in powershell
Oh, I may have figured it out- I may just have to change $False to $True...
if that doesn't work I'll look at $session.removefiles
Correct. Set the remove argument of the Session.GetFiles to $True:
$transferResult = $session.GetFiles("/directory/XDOWNLOADS/fileA", "c:\windowsdirectory\fileA", $True, $transferOptions)
See:
https://winscp.net/eng/docs/library_session_getfiles
https://winscp.net/eng/docs/scriptcommand_get#net
