"Server refused to start a shell/command" error with 3.7.5 b
KeithG
Hello all!
I have run into a problem with WinSCP 3.7.5 beta.
When I try to login to one particular server I get the error "Server refused to start a shell/command".
Using version 3.7.4 I'm able to login without any problems.
I am using the Norton interface
The remote system is a FreeBSD 4.3 box.
Thanks for any help with this!
Here are the debug logs:
WinSCP Version 3.7.4 (Build 271) (OS 5.1.2600 Service Pack 2)
Login time: Wednesday, July 20, 2005 9:24:45 AM
Session name: State
Host name: 172.16.1.2 (Port: 22)
User name: xxxxxxx (Password: No, Key file: No)
Transfer Protocol: SFTP (SCP)
SSH protocol version: 2; Compression: Yes
Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
SSH Bugs: -,-,-,-,-,-,-,-
SFTP Bugs: -,-,-
Proxy: none
Return code variable: Autodetect; Lookup user groups: Yes
Shell: default, EOL: 0
Local directory: C:\, Remote directory: home, Update: No, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
Looking up host "172.16.1.2"
Connecting to 172.16.1.2 port 22
Server version: SSH-1.99-OpenSSH_2.3.0 green@FreeBSD.org 20010321
We believe remote version has SSH2 rekey bug
We claim version: SSH-2.0-WinSCP_release_3.7.4
Using SSH protocol version 2
Doing Diffie-Hellman group exchange
Doing Diffie-Hellman key exchange
Host key fingerprint is:
ssh-dss 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
Initialised AES-256 client->server encryption
Initialised HMAC-SHA1 client->server MAC algorithm
Initialised zlib (RFC1950) compression
Initialised AES-256 server->client encryption
Initialised HMAC-SHA1 server->client MAC algorithm
Initialised zlib (RFC1950) decompression
Using username "xxxxxxx".
Session password prompt (xxxxxxx@172.16.1.2's password: )
Asking user for password.
Sent password
Access granted
Opened channel for session
Primary command failed; attempting fallback
Started a shell/command
Using SCP protocol.
Doing startup conversation with host.
Skipping host startup message (if any).
<snip>
and for 3.7.5 beta
. 2005-07-20 09:50:20.265 --------------------------------------------------------------------------
. 2005-07-20 09:50:20.265 WinSCP Version 3.7.5 (Build 294) (OS 5.1.2600 Service Pack 2)
. 2005-07-20 09:50:20.265 Login time: Wednesday, July 20, 2005 9:50:20 AM
. 2005-07-20 09:50:20.265 Session name: State
. 2005-07-20 09:50:20.265 Host name: 172.16.1.2 (Port: 22)
. 2005-07-20 09:50:20.265 User name: xxxxxxx (Password: No, Key file: No)
. 2005-07-20 09:50:20.265 Transfer Protocol: SFTP (SCP)
. 2005-07-20 09:50:20.265 SSH protocol version: 2; Compression: Yes
. 2005-07-20 09:50:20.265 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-07-20 09:50:20.265 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-07-20 09:50:20.265 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-07-20 09:50:20.265 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-07-20 09:50:20.265 SFTP Bugs: -,-,-
. 2005-07-20 09:50:20.265 Proxy: none
. 2005-07-20 09:50:20.265 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-07-20 09:50:20.265 Shell: default, EOL: 0
. 2005-07-20 09:50:20.265 Local directory: C:\, Remote directory: home, Update: No, Cache: Yes
. 2005-07-20 09:50:20.265 Cache directory changes: Yes, Permanent: Yes
. 2005-07-20 09:50:20.265 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-07-20 09:50:20.265 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-07-20 09:50:20.265 Looking up host "172.16.1.2"
. 2005-07-20 09:50:20.265 Connecting to 172.16.1.2 port 22
. 2005-07-20 09:50:20.281 Server version: SSH-1.99-OpenSSH_2.3.0 green@FreeBSD.org 20010321
. 2005-07-20 09:50:20.281 We believe remote version has SSH-2 rekey bug
. 2005-07-20 09:50:20.281 We claim version: SSH-2.0-WinSCP_release_3.7.5
. 2005-07-20 09:50:20.281 Using SSH protocol version 2
. 2005-07-20 09:50:20.281 Doing Diffie-Hellman group exchange
. 2005-07-20 09:50:20.406 Doing Diffie-Hellman key exchange
. 2005-07-20 09:50:20.562 Host key fingerprint is:
. 2005-07-20 09:50:20.562 ssh-dss 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
. 2005-07-20 09:50:20.562 Initialised AES-256 client->server encryption
. 2005-07-20 09:50:20.562 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-07-20 09:50:20.562 Initialised zlib (RFC1950) compression
. 2005-07-20 09:50:20.562 Initialised AES-256 server->client encryption
. 2005-07-20 09:50:20.562 Initialised HMAC-SHA1 server->client MAC algorithm
. 2005-07-20 09:50:20.562 Initialised zlib (RFC1950) decompression
! 2005-07-20 09:50:20.562 Using username "xxxxxxx".
. 2005-07-20 09:50:20.578 Session password prompt (xxxxxxx@172.16.1.2's password: )
. 2005-07-20 09:50:20.578 Asking user for password.
. 2005-07-20 09:50:23.718 Sent password
. 2005-07-20 09:50:23.734 Access granted
. 2005-07-20 09:50:23.734 Opened channel for session
. 2005-07-20 09:50:23.734 Server refused to start a shell/command
* 2005-07-20 09:50:23.734 (ESshFatal) Authentication failed.
* 2005-07-20 09:50:23.734 Authentication log (see session log for details):
* 2005-07-20 09:50:23.734 Using username "xxxxxxx".
* 2005-07-20 09:50:23.734 Server refused to start a shell/command
Re: "Server refused to start a shell/command" error with 3.7.5 b
SCP fallback is broken in WinSCP 3.7.5. You need to request SCP protocol explicitly on login dialog.
KeithG
That did the trick!!
Thanks so much for the quick reply!
vj
Is there a way to set the SCP protocol in a script file?
"open scp://session". See "help open".
