5.77 import sessions and other questions
nova
fresh install of 5.77, asked if I want to imports putty sessions. I said No and it does it anyway.. then when trying to use sessions it doesn't prompt for my username but instead just for password... entering it wont allow me to login.
I delete session recreate and it now prompts for login and password correctly and lets me in once credentials are entered
Re: 5.77 import sessions and other questions
Can you reproduce the problem?
- Backup your configuration. https://winscp.net/eng/docs/config#export
- Uninstall WinSCP, let it delete the configuration while uninstalling
- Install again and check if the sessions got imported even if you reject that.
After the test, import your configuration back: https://winscp.net/eng/docs/config#import
Btw, didn't you have WinSCP installed in the past? You might have the sessions stored since then.
