Getting files over SSH from Linux server to Windows 7, files downloaded each time
RobertMer
Hello people, the problem is that all the files on the server are downloaded each time I run the software, even if they are already present.
I read about an issue with time stamps, but I'm using "-criteria=none", shouldn't that only see if a file exist and download only in that case?
Thanks for any ideas.
option batch on
open user:password@host
option transfer binary
synchronize -criteria=none local C:\FilesFromServer /RemoteFolder/*
Re: Getting files over SSH from Linux server to Windows 7, files downloaded each time
There are over hundred files in the remote directory and only about ten were downloaded.
So the log does not confirm that "all the files on the server are downloaded each time I run the software".
What file was downloaded that should not have been?
RoberMer
Hey! Thanks.
Strangely it stopped doing it. If it happens again, I'll remove all files but 5 or 10 so troubleshooting is easier, but it's weird, it's not doing that anymore.
