error code: 5 after 2GB
igor
Hi. I'm having problems downloading files larger than 2GB.
Protocol was SFTPv3. I did not try SCP because my connection is not that good and since it does not support resuming I had no other choice.
After copying 2GB I get following message.
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server: Bad message
Request code: 5
I'm not quite sure what's the reason for this.
From your FAQ I've found out that SFTPv3 should be able of transfer larger than 4GB.
The file was in a SMB-mounted directory. Could it be there is something wrong with the Samba thing ?
Best,
Igor
Re: error code: 5 after 2GB
I do not know where the problem can bem, sorry :-( WinSCP definitelly supports files over 2GB with SFTPv3. BTW, what version of WinSCP are you using?
igor
I've tried it with the latest and a few older versions of WinSCP... no luck. ok.. I'll try to find another way to get those files... thanks anyway.
Dragan wrote:
Does the problem occur with WinSCP 4.1.9 ?
I am having the same problem too. My version of WinSCP is 4.2.5.
Thanks.
