Upgrade problem
jlbundy
Upgrade problem
I, unfortunately, accepted an upgrade to 5.7.6 now the SSIS package that was working just fine, fails. I have deleted and recreated the Execute Process Task using the exact same parameters and script file, but of course the package now refuses to execute. Does anyone have any suggestions?
Re: Upgrade problem
How is it failing? Do you use scripting or .NET assembly in the SSIS?
