IPv6 SSH-Tunneling
manawyrm
Alfeld (Leine)
IPv6 SSH-Tunneling
I am currently trying to connect to an IPv6-only host via WinSCPs tunneling function.
This is the configuration I'm using:
<invalid link removed>
When connecting, instead of establishing the connection, it just shows this error message:
I have tried the current nightly build, but apart from the nicer error icon :mrgreen: , nothing changes:
The issue can be reproduced with OpenSSH and dropbear SSH servers.
Any ideas?
Thank you very much,
Tobias
Re: IPv6 SSH-Tunneling
Please attach a full log file showing the problem.
manawyrm
Alfeld (Leine)
I will post a log shortly.
In the meantime I have figured out, that putting the IPv6 address in [ ] brackets fixes the problem.
EDIT: Log is now attached.
Best regards,
Tobias
manawyrm
Alfeld (Leine)
That might be part of the problem :mrgreen:
I have used IPv6 addresses to connect in this log.
Does WinSCP internally use PuTTY to provide this tunneling feature?
If so: I figured out, that PuTTY needs square brackets around an IPv6 address to make it work.
It might be enough to just encapsulate every IPv6 address in [ ] if it is sent to your tunneling method.
So long,
Tobias
I do not think so. WinSCP logs the IP address exactly as your enter it. Can you please try again? Posting a screenshot and a corresponding log file?
