MV Command appends from location at the end of the to location
CaritoBito
Ok. Tried this multiple ways. Have a file on remote server and I'm trying to move it to another location.
I've tried a drive mapping and UNC path method for the from location.
Mapped windows drive to Z:\testfile.txt
And tried its UNC path
\\IP\folder1\folder2\testfile.txt
When I do this or use the unc path instead...
MV Z:\testfile.txt /secondlocation/folder1/folder2/testfile.txt
MV Z:\testfile.txt /secondlocation/folder1/folder2/*.txt
MV Z:\*.txt /secondlocation/folder1/folder2/*.txt
I get this in the error:
Error moving file 'Z:\testfile.txt' to '/secondlocation/folder1/folder2/Z:\testfile.txt
No such file or directory.
Error code: 2
Why is it adding the from location to the end of the second location? I get the UNC prob cant be used but if I do this PUT Z:\testfile.txt /secondlocation/folder1/folder2/testfile.txt it works just fine.
THX for any help
Re: MV Command appends from location at the end of the to location
The mv command is for moving remote file to another remote location.
To move a local file to remote directory, use put -delete.
