ProgressBar update
MrVinc
Ger
ProgressBar update
I upload files via SCP and want to see the status in a ProgressBar.
How did I update the ProgressBar?
Here my code for the upload with a BackgroundWorker:
private void frm_main_Load(object sender, EventArgs e)
    worker = new BackgroundWorker();
    worker.WorkerReportsProgress = true;
    worker.WorkerSupportsCancellation = true;
    worker.DoWork += new DoWorkEventHandler(worker_DoWork);
private void btn_hochladen_Click(object sender, EventArgs e)
    worker.RunWorkerAsync(2000);
void worker_DoWork(object sender, DoWorkEventArgs e)
    if (arguments.Length > 1)
        for (int i = 1; i < arguments.Length; i++) // Loop through array
                // Connect
                session.Open(sessionOptions);
                // Upload files
                transferOptions.TransferMode = TransferMode.Binary;
                TransferOperationResult transferResult;
                string path = "/recalbox/share/roms/" + folder + "/";
                transferResult = session.PutFiles(@"" + String.Join(", ", arguments[i]), path, false, transferOptions);
                //transferResult = session.PutFiles(@"" + String.Join(", ", arguments[i]), "/recalbox/share/test/", false, transferOptions);
                // Throw on any error
                transferResult.Check();
                // Print results
                //foreach (TransferEventArgs transfer in transferResult.Transfers)
                //    MessageBox.Show(transfer.FileName);
