Network error: Connection refused
When I login using Version 3.1.0, there is a "searching host" notice, and then an error message -- "Network error: Connection refused". This happens with every setting I have tried (SCP, SCTP, etc.; Default, /bin/bash or /bin/ksh; LF[10] (Unix) or CR/LF [13/10] (Windows) EOL characters). I know this system has worked on this computer in the past. Is there anything that would be causing this?
I have tried using the latest release (3.7.5) and have found the same results. Here is a session log:
ed
. 2005-07-13 11:23:24.494 --------------------------------------------------------------------------
. 2005-07-13 11:23:24.515 WinSCP Version 3.7.5 (Build 294) (OS 5.1.2600 Service Pack 2)
. 2005-07-13 11:23:24.515 Login time: July 13, 2005 11:23:24 AM
. 2005-07-13 11:23:24.515 --------------------------------------------------------------------------
. 2005-07-13 11:23:24.515 Session name: facweb@esker.geog.utoronto.ca
. 2005-07-13 11:23:24.515 Host name: esker.geog.utoronto.ca (Port: 22)
. 2005-07-13 11:23:24.515 User name: facweb (Password: Yes, Key file: No)
. 2005-07-13 11:23:24.515 Transfer Protocol: SCP
. 2005-07-13 11:23:24.515 SSH protocol version: 2; Compression: No
. 2005-07-13 11:23:24.515 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-07-13 11:23:24.515 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-07-13 11:23:24.515 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-07-13 11:23:24.515 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-07-13 11:23:24.515 SFTP Bugs: -,-,-
. 2005-07-13 11:23:24.515 Proxy: none
. 2005-07-13 11:23:24.515 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-07-13 11:23:24.515 Shell: default, EOL: 0
. 2005-07-13 11:23:24.515 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-07-13 11:23:24.515 Cache directory changes: Yes, Permanent: Yes
. 2005-07-13 11:23:24.515 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-07-13 11:23:24.515 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-07-13 11:23:24.515 Looking up host "esker.geog.utoronto.ca"
. 2005-07-13 11:23:24.735 Connecting to 128.100.66.4 port 22
. 2005-07-13 11:23:25.646 Failed to connect to 128.100.66.4: Network error: Connection refused
. 2005-07-13 11:23:25.646 Attempt to close connection due to fatal exception:
* 2005-07-13 11:23:25.646 Network error: Connection refused
. 2005-07-13 11:23:25.646 Closing connection.
* 2005-07-13 11:23:25.646 (ESshFatal) Network error: Connection refused
Thanks again
Re: Network error: Connection refused
Are you sure that SSH server is running on the other end? It can also be firewall issue.
