CD command hangs and exits using FTP
ryanjcaldwell
I am using WinSCP.com , Version 5.7.6 (Build 5874)
Using FTP
When I issue the command "cd /ifs/services/webvod/" the program hangs for about 8 secs then exits.
I believe the issue is related to the fact the user does not have permissions for the parent directory "/ifs/services" but full access to the child directories.
This works fine with other FTP Utilities but I would like to use WinSCP for scripting purposes.
Ryan
Here is a partial log:
2016-02-19 10:21:02.713 Connected with ******************. Waiting for welcome message...
< 2016-02-19 10:21:02.723 220-Isilon OneFS v7.2.0.1
> 2016-02-19 10:21:02.723 USER *************
< 2016-02-19 10:21:02.723 331 Please specify the password.
> 2016-02-19 10:21:05.238 PASS *******
< 2016-02-19 10:21:05.346 230 Login successful.
> 2016-02-19 10:21:05.346 SYST
< 2016-02-19 10:21:05.346 215 UNIX Type: L8
> 2016-02-19 10:21:05.346 FEAT
< 2016-02-19 10:21:05.346 211-Features:
< 2016-02-19 10:21:05.356 EPRT
< 2016-02-19 10:21:05.356 EPSV
< 2016-02-19 10:21:05.356 MDTM
< 2016-02-19 10:21:05.356 PASV
< 2016-02-19 10:21:05.356 REST STREAM
< 2016-02-19 10:21:05.356 SIZE
< 2016-02-19 10:21:05.356 TVFS
< 2016-02-19 10:21:05.356 UTF8
< 2016-02-19 10:21:05.356 211 End
> 2016-02-19 10:21:05.356 OPTS UTF8 ON
< 2016-02-19 10:21:05.356 200 Always in UTF8 mode.
. 2016-02-19 10:21:05.356 Connected
. 2016-02-19 10:21:05.356 --------------------------------------------------------------------------
. 2016-02-19 10:21:05.356 Using FTP protocol.
. 2016-02-19 10:21:05.358 Doing startup conversation with host.
> 2016-02-19 10:21:05.358 PWD
< 2016-02-19 10:21:05.361 257 "/ifs/home/NTD1"
. 2016-02-19 10:21:05.361 Getting current directory name.
. 2016-02-19 10:21:05.361 Startup conversation with host finished.
< 2016-02-19 10:21:05.361 Script: Active session: [1] ************
> 2016-02-19 10:21:17.136 Script: cd /ifs/services/webvod
. 2016-02-19 10:21:17.136 Changing directory to "/ifs/services/webvod".
> 2016-02-19 10:21:17.136 CWD /ifs/services/webvod
< 2016-02-19 10:21:17.136 250 Directory successfully changed.
. 2016-02-19 10:21:17.136 Getting current directory name.
> 2016-02-19 10:21:17.136 PWD
< 2016-02-19 10:21:17.139 257 ""
. 2016-02-19 10:21:17.141 Getting current directory name.
> 2016-02-19 10:21:17.141 PWD
< 2016-02-19 10:21:17.141 257 ""
> 2016-02-19 10:21:17.144 PWD
< 2016-02-19 10:21:17.144 257 ""
. 2016-02-19 10:21:17.144 Getting current directory name.
this repeats about 18,000 times
Re: CD command hangs and exits using FTP
