using the find feature to search directories
clint342
MN
i would like to search in a location called /incoming/space/
within this location are approx 200 folders each having the same set of sub folders
example name of folder is A000088800, there are 200 of these with diff names under /incoming/space
example of a sub folder is X12_Trans, each of the 200 folders contains this sub folder
at any given time, from /incoming/virtual, i would like to search for any files located in all of the X12_Trans folders.
how do set the "file mask" and "search in" fields to accomplish this ? thank you john
szczeciu
search folder
can we search for folders using winscp yet ?
or a certain mask like exploit in prestashop:
vendor/phpunit ??
Re: search folder
https://winscp.net/tracker/1819
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
