Server refused to start a shell/command
Darryl777
Birmingham, AL
Hey Guys,
Newbie to WinSCP and ftp in general. I'm getting the error above when I try to change directory using Session.ExecuteCommand("CWD reports"); Using Protocol.Sftp
Thanks,
Darryl
Re: Server refused to start a shell/command
First, the CWD is FTP command, it can hardly work with a shell session that SFTP connection opens to execute an connect.
In shell you use cd.
But your server does not allow you to open the shell session anyway.
What are you trying to do?
Darryl777
Birmingham, AL
Thanks for the reply. Our vendor is moving from ftp to sftp and we were attempting to modify the least amount of code as possible. Our old stuff relied on using commands. Did not realize the inherent differences in the two technologies. We got it working in sftp. Thanks!
