Disable ResumeSupport in Powershell
Jstannard
I am trying to write a file to an ftp server where I only have write access, not modify. I am having a problem because I get back
Cannot create remote file '/xxx.filepart'.
The documentation suggests this is because I do not have modify access. I did this WinSCP -> Preferences -> Endurance -> Disable
I checked the winscp.ini file and ResumeSupport = 2 ( I believe this means disabled). I ran "echo $transferOptions.ResumeSupport" and it says that it is in a default state.
I have checked this documentation:
https://winscp.net/eng/docs/ui_pref_resume
https://winscp.net/eng/docs/library_transferoptions#resumesupport
However, I don't see a powershell example, just C#.
I have tried various permutations of $transferOptions.ResumeSupport.State = Off, $transferOptions.ResumeSupport.Off, and whatnot. One of these says that it's read-only.
Thanks in advance for help,
Jay
Re: Disable ResumeSupport in Powershell
My response to your duplicate post on Stack Overflow:
https://stackoverflow.com/q/35278404/850848
Syntax for using enumeration in PowerShell is described in
article Using WinSCP .NET assembly from PowerShell.
Enumeration values are accessed using static field syntax [Namespace.Type]::Member, for example [WinSCP.Protocol]::Sftp.
You can find a PowerShell example for TransferResumeSupport.State in Converting to .NET assembly section of get and put command documentation:
$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
$session.GetFiles(..., ..., $False, $transferOptions).Check()
