Can't log in through command line. Can login via GUID.
Niftykettles
Hi.
I can log in via the GUID fine. However when I try running a script containing the password it fails.
Here is the script:
echo open sftp.myuser:4FHe40;r@sftp.myserver.com >> c:\FTP\Script.tmp
The only thing I thought it might be was the ';' in the password but I've tried escaping it with a ^ and % to no avail. I've also tried:
echo open "sftp.myuser:4FHe40;r@sftp.myserver.com" >> c:\FTP\Script.tmp.
I've also tried using a generated session URL and it still fails.
Here is the log file:
. 2016-02-05 09:16:27.063 Initialised HMAC-SHA1 client->server MAC algorithm
. 2016-02-05 09:16:27.063 Initialised AES-256 CBC server->client encryption
. 2016-02-05 09:16:27.063 Initialised HMAC-SHA1 server->client MAC algorithm
! 2016-02-05 09:16:27.079 Using username "sftp.myuser".
. 2016-02-05 09:16:27.079 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2016-02-05 09:16:27.079 Using stored password.
. 2016-02-05 09:16:27.095 Sent password
. 2016-02-05 09:16:27.095 Password authentication failed
! 2016-02-05 09:16:27.095 Access denied
. 2016-02-05 09:16:27.095 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2016-02-05 09:16:27.095 Disconnected: Unable to authenticate
Any help appreciated
Re: Can't log in through command line. Can login via GUID.
Enable password logging and show a attach a log file both from GUI and scripting.
