Directory Deleted Unexpectly During GetFiles
mjhillman
New Jersey
When getting files from directory outgoing all the files are removed (expected) and the outgoing directory is deleted (unexpected).
transferResult = session.GetFiles(ftpDirectory, dataDir, true, transferOptions);
Is this the normal behavior?
I am executing this code in an SSIS script.
Thanks.
Mike
. 2016-02-01 12:35:55.053 File: '/fpl/outgoing/paid_20160129_1159.txt' [2016-01-29T16:59:14.000Z] [2]
. 2016-02-01 12:35:55.054 Copying "/fpl/outgoing/paid_20160129_1159.txt" to local directory started.
. 2016-02-01 12:35:55.054 Binary transfer mode selected.
. 2016-02-01 12:35:55.054 Opening remote file.
> 2016-02-01 12:35:55.054 Type: SSH_FXP_OPEN, Size: 53, Number: 40963
< 2016-02-01 12:35:55.093 Type: SSH_FXP_HANDLE, Size: 19, Number: 40963
> 2016-02-01 12:35:55.094 Type: SSH_FXP_FSTAT, Size: 19, Number: 41224
< 2016-02-01 12:35:55.132 Type: SSH_FXP_ATTRS, Size: 29, Number: 41224
> 2016-02-01 12:35:55.133 Type: SSH_FXP_READ, Size: 31, Number: 41477
< 2016-02-01 12:35:55.213 Status code: 1
. 2016-02-01 12:35:55.213 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2016-02-01 12:35:55.213 Type: SSH_FXP_CLOSE, Size: 19, Number: 41988
. 2016-02-01 12:35:55.213 Preserving timestamp [2016-01-29T16:59:14.000Z]
. 2016-02-01 12:35:55.214 Deleting file "/fpl/outgoing/paid_20160129_1159.txt".
> 2016-02-01 12:35:55.214 Type: SSH_FXP_REMOVE, Size: 45, Number: 42253
< 2016-02-01 12:35:55.273 Type: SSH_FXP_STATUS, Size: 30, Number: 41988
. 2016-02-01 12:35:55.273 Discarding reserved response
< 2016-02-01 12:35:55.313 Type: SSH_FXP_STATUS, Size: 29, Number: 42253
< 2016-02-01 12:35:55.313 Status code: 0
. 2016-02-01 12:35:55.313 Deleting file "/fpl/outgoing".
> 2016-02-01 12:35:55.313 Type: SSH_FXP_RMDIR, Size: 22, Number: 42511
< 2016-02-01 12:35:55.367 Type: SSH_FXP_STATUS, Size: 34, Number: 42511
< 2016-02-01 12:35:55.367 Status code: 0
> 2016-02-01 12:35:55.522 Script: exit
. 2016-02-01 12:35:55.522 Script: Exit code: 0
. 2016-02-01 12:35:55.522 Closing connection.
. 2016-02-01 12:35:55.522 Sending special code: 12
. 2016-02-01 12:35:55.522 Sent EOF message
