Excel VBA sessionoption object returns Activex cannot create object error
karthiknsra
MK
I have recently registered the winscpnet.dll using .NET Framework C:\Windows\Microsoft.NET\Framework64\v2.0.50727. And I have added the tlb file generated to my VBA references. But when I try to instantiate sessionoptions object, it throws an error "Activex cannot create object". Not sure what went wrong here. Could you please guide.
Regards
Karthik
Re: Excel VBA sessionoption object returns Activex cannot create object error
My answer to your duplicate post on Stack Overflow:
https://stackoverflow.com/q/35091706/850848
The Microsoft Excel is 32-bit application, so you probably have to register the WinSCPnet.dll for 32-bit .NET framework, even on 64-bit system.
As the instructions for registering the WinSCP .NET assembly for COM shows, on 64-bit system, you generally need to register the assembly both for 32-bit and 64-bit:
%WINDIR%\Microsoft.NET\Framework\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet32.tlb
%WINDIR%\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet64.tlb
Do not add the .tbl manually to Excel. The assembly appears itself after being registered correctly.
karthiknsra wrote:
Thank you so much. This resolved the problem.
You are welcome. Can you accept my answer on Stack Overflow to close the question?
