Archive files when winscp backup is done?
DarkCloud
Norway
Hi
I am running a scrip for backing up my remote web server files over SFTP, and its working great with task scheduler, so all OK :)
What i would like, is to have the same script zip/rar the files before it exit, preferably with dated filename so that i can have mutiple backup stored localy.
any tips on what to add to my script?
option batch on
# Connect - format: user:password@host
open winscp-sftp://user:password@host
# Change remote directory
cd /home/
# Force binary mode transfer
option transfer binary
# Download backup file to the local directory
get *.* P:\Backup\
# Disconnect
close
# Exit WinSCP
DC
Re: Archive files when winscp backup is done?
That's not a task for WinSCP.
Just wrap the WinSCP call to a batch file and archive/compress the files from the batch file after WinSCP finishes.
