Problems Running Script
jchornsey
Colorado, USA
I'm trying to execute WinSCP with a script from within PowerShell. I've created the PS script so that it creates the WinSCP script file programmatically based on yesterday's date.
The script file is created successfully and when I execute those steps from within "winscp.exe /console" or "winscp.com", each of the steps work perfectly.
However, when I try to execute from a command line with the "/script" switch, either nothing appears to happen, or I get an error.
Nothing is generated with the "/log" switch.
c:\Program Files (x86)\WinSCP>winscp.exe /console /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp.com /console /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
No mapping for the Unicode character exists in the target multi-byte code page
c:\Program Files (x86)\WinSCP>winscp.com /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp.exe /script="I:\scripts\2016-01-21.txt" /log="I:\log.txt"
c:\Program Files (x86)\WinSCP>winscp /script=I:\scripts\2016-01-21.txt /log=I:\log.txt
Any ideas?
jchornsey
Colorado, USA
The "code" section is from the command prompt.
If I run the script command from within 'winscp.exe /console' or 'winscp.com', each of the commands in the script run fine.
When I try to execute with the '/script' switch, nothing happens. Or, I get the unicode mapping error.
I've never seen that "Unicode" error before.
What happens when you use winscp.exe /console /script=...? Does console window popup?
jchornsey
Colorado, USA
It does, but it disappears so quickly, I can't see if it actually did anything.
And, with the /log switch, nothing is logged.
Are you sure you have a write access to that I: drive? Could you try to log to a local drive instead (like %TEMP%)?
What happens when you use winscp.com from Start > Run instead of a cmd.exe console/command-line?
What happens when you use winscp.com from console/command-line and redirect its output to a local file?
jchornsey
Thanks for your comments and suggestions. Unfortunately, I wasn't able to get past the error. So, I just wrote the script to use the built-in Microsoft FTP client.
Thanks, though!
kkas
I'm experiencing same behaviour.
It worked once, after making one line change in script -txt file, got code page mapping error.
put -nopermissions -filemask="*>=1D" *
Used ver 5.7.6. and 5.8.1b
Works ok with winscp.exe /console /script=
C:\Temp>winscp.com /script=C:\temp\upload_script.txt /log=C:\temp\winscp.log /loglevel=0
C:\Temp>"C:\Program Files (x86)\WinSCP\start_script.bat"
C:\Temp>winscp.com /script="C:\Program Files (x86)\WinSCP\upload_script.txt" /log="C:\Program Files (x86)\WinSCP\winscp.log" /loglevel=0
BR,
Kimmo
Cassu
Script
Here you go, had to remove actual address and key.
All commands are working perfectly with CLI. Starting this with .bat and task scheduler bugs..
open scp://xxxx@1.2.3.4 / -hostkey="ssh-rsa 2048 key" -privatekey="C:\Program Files (x86)\WinSCP\hostname_private_ssh_key_wo_pass" -rawsettings AgentFwd=1
# Change local directory
lcd z:\
# Force ascii mode transfer
option transfer ascii
# command
pwd
# command
ls
# put 24h modifioidut -nopermissions
pwd
ls
BR,
Kimmo
Re: Script
The script looks good. Though I really mean, if you can attach it as a file?
What was the one line change you did?
MarcoFR73
I found the solution
Hi all.
I had same problem.
The file script was wrote under Windows, but the server witch I was wanting to access is an Unix server.
Finally, I rewrote the script under Unix, with vi.
And that's fine.
ps : sorry for my bad english...
