Progressbar in background transfer window possible?
c.hasselfeldt
Hello all,
I'm new to WinSCP and I'm enthusiastic about your client. Keep up the good work!
But one question:
It would be nice if there would be a progress bar at transfers in the background. I have so far only a percentage display. Did I miss something?
Thanks for your support
Carsten
Re: Progressbar in background transfer window possible?
The progress bar shows on WinSCP taskbar button. Doesn't it? What version of WinSCP and Windows are you using?
