Change default action on double click?
spook
Is there any way to change the default action on double-click from 'Open' to 'Edit'?
I have associated the .php extension with Notepad++ in windows but it only works properly when opened through the Edit option (due to the MDI functionality of notepad++).
I've found another post here which mentions that it is possible to change the default double click action, but I can't find the option. I'm using v3.7.4.
Thanks for any help!
Spook
Re: Change default action on double click?
You cannot change default action of double-click to "edit" yet. Next version will allow that.
