Does this delete work in FTP?
Philky001
session.GetFiles(RemotePath + "/" + fileInfo.Name, LocalPath + fileInfo.Name, true).Check();
this works when I coded for SFTP. But the same for FTP is not making the delete on the server. Is there any other parameters needed?
Re: Does this delete work in FTP?
Yes, it should work.
If you have problems, please attach a full session log file showing the problem (using the latest version of WinSCP).
