can't synchronize both while @echo off
Szarky
I created 2 sripts
first:
@echo off
winscp.com /script=sync.bat
second:
@echo off
open sftp://username:password@host.com
synchronize both c:\local /home/remote
and crated task in scheduler to run first script every 10 minutes. Every 10 minutes i see prompt window hiding, propably from first script. but when I refresh remote folder-nothing changes.
I had to delete @echo off from second file to get this working properly, but this window is quite annoynig.
My OS is Windows 10 Edu
Deon
synchronize more files
hi please help i have the same code and i was wondering if i could sync more than one at a time my text looks like this
open Mywebsite.com
synchronize remote "Z:\Backup\Business\WEB\Folder A\Folder B\" "/home/public_html/Folder A/Folder B/"
synchronize remote "Z:\Backup\Business\WEB\Folder C\Folder D\" "/home/public_html/Folder C/Folder D/"
When i have the one like this
open Mywebsite.com
It works perfect but as soon as i add more only the first one keeps going through but not the second or third one
Thank you
Re: synchronize more files
