File mask bug
HWitche
New York
File mask bug
Hi all,
for some weird reasons the "file mask" option "Use same option next time" doesn't work.
I use OS Window 7 and I have the newest version of WinSCP installed.
I click the checkbox, but the program simply doesn't remember my settings.
all the best
Hans
Reply with quote E-mail
Re: File mask bug
Can you provide us more details? Step by step instructions to reproduce the bug? Maybe with few screenshots?
Dear Martin Prikryl,
I think your program is magnificent and I hope to provide you with the necessary information to tackle the problem:
WinSCP Version 5.7.6.
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
System Manufacturer LENOVO
System Model 20DLCTO1WW
System Type x64-based PC
Processor Intel(R) Core(TM) i7-5600U CPU @ 2.60GHz, 2601 Mhz, 2 Core(s), 4 Logical Processor(s)
here my steps:
1) click "Synchronize"
2) click "Transfer Settings" (screenshot)
3) go to "Other: > "File Mask"
4) writting mask into field
5) click OK > close "Transfer Settings"
6) click checkmark "Use same option next time" (screenshot)
7) OK
8) The Task is then flawlessly executed by WinSCP
9) but in the following synchronization, the mask in the "Use same option next time" has disappeared and the checkmark is empty
10) and that means I have to go to step 3 and repeat procedure (screenshot)
best
Hans
H_ans
Got it.
Maybe in a later version it would be possible to enter those masks for each new connection to a specific DIR individually.
Thank you
Hans
H_ans
Re: "file mask" option "Use same option next time" doesn't work
WinSCP supports autoselection rules for transfer settings. So the settings can be host- and directory-specific.
See https://winscp.net/eng/docs/ui_transfer_preset
https://winscp.net/eng/docs/transfer_settings#presets
Thank you Martin,
I see now how it works -- quite hidden and not so obvious -- so please forgive me, for my last question:
for what is the "Use same option next time" in the "Transfer Settings" window then?
best
Hans
I assume you have meant "Synchronize" dialog.
It's to remember the synchronization options.
HWitche
New York
turn off Optimize connection buffer size
Hi Martin,
I can't find the button or setting to turn off "Optimize connection buffer size".
Is there one or planned in a future version?
all the best
Hans
PS: also I couldn't find a link to post a new topic on the beautifully new designed website, well, it could be me because it's a friday...
[/img]
Description: it seems like easy to do...
HWitche
New York
thank you! Martin
Got it.
A bit tricky, actually not possible to find, while connected to remote.
Maybe the instruction should be:
1) Disconnect
2) highlight Session
3) click Edit
4) click Advanced
5) etc...
but anyway thank you Martin for your great program!
