Pause for auto update
Toadmyster
Is there a way to pause the auto update. I have audio files that automatically record clips in 15 minute intervals. I would like the auto update to pause while the audio file is finished being recorded. The auto update is detecting a change every 2 seconds, uploads the file, then keeps detecting the change as the file has not finished recording.
Toadmyster
So it should look like this?
bat file:
:Loop
winscp.com /script=script.txt ^
    "option batch abort" ^
    "open <session>" ^
    "synchronize remote <local directory> <remote directory>" ^
    "exit"
timeout 10
goto :Loop
txt file:
open sftp://user:password@webiste
synchronize remote filemask=|>15N "C:\Users\ME\Desktop\folder\" "/home/website/public_html/folder/"
Like this:
:Loop
timeout 10
goto :Loop
The script file is good.
Or like this and you do not need the script file:
:Loop
winscp.com /command ^
    "open sftp://user:password@webiste" ^
    "synchronize remote filemask=|>15N ""C:\Users\ME\Desktop\folder\"" ""/home/website/public_html/folder/""" ^
    "exit"
timeout 10
goto :Loop
Toadmyster
When I double click on the .bat file, the windows command prompt opens and this is all that happens:
C:\Program Files (x86)\WinSCP>winscp.com /command
winscp>
Should I be executing it another way?
Thanks for your help by the way!
