Sync Folder from Window to Linux - Uploaded file permission not change
nevil_doshi
I am synchronize my windows folder to linux folder.
I change transfer options file permission but it remains default (rw------)
My Code is as below:
Protocol = Protocol.Ftp,
HostName = xxxxx,
UserName = xxxxx,
Password = xxxxx,
session.FileTransferred += FileTransferred;
session.Open(sessionOptions);
TransferOptions option = new TransferOptions();
FilePermissions filePermission = new FilePermissions();
filePermission.GroupExecute = true;
filePermission.GroupRead = true;
filePermission.GroupWrite = true;
filePermission.OtherExecute = true;
filePermission.OtherRead = true;
filePermission.OtherWrite = true;
filePermission.UserExecute = true;
filePermission.UserRead = true;
filePermission.UserWrite = true;
option.FilePermissions = filePermission;
SynchronizationResult synchronizationResult;
synchronizationResult =
session.SynchronizeDirectories(
SynchronizationMode.Remote, local folder path, remote folder path, false, false, SynchronizationCriteria.Size, option);
synchronizationResult.Check();
Re: Sync Folder from Window to Linux - Uploaded file permission not change
Do you expect the code to change permissions of the existing remote files? (it won't)
Or is the problem even with newly uploaded (synchronized) files?
nevil_doshi
Thanks for your reply..
My issue was solved actually I am using EC2 instance and I access one folder by FTP user and also by web(www-data) so there is some issue regarding permission when new file is created by FTP user.
It is solved by changing permission of FTP user on server side.
Thanks for your time..
Regards,
Nevil Doshi
