Error popup on mouseover event with the custom command buttons bar
Jocko
France
If the custom command buttons bar is not anchored (so a floating bar), I got an error message when the mouse is over a button.(see the attached screen capture)
This happens after upgrading winscp (winscp 5.8 beta Build 6030 on a Windows 7)
Note: However the related custom command is run after clicking on the button.
Re: Error popup on mouseover event with the custom command buttons bar
https://winscp.net/tracker/1385
Jocko
France
Indeed with your latest version (5.8.1 Dev Build 6096), failure messages disappeared on mouseover events with any floating toolbar.
Attached my rnd file
  • winscp.rar (674 Bytes, Private file)
