CLI: Get subfolders/files that are older than x minutes even if root folder mod date has changed
Guest1970
I am trying to Get subfolders/files that are older than x minutes. I have noticed that if the root folder modify date has changed and there are subfolders/files that are older than x, no files are downloaded.
Is there a way to still get the subfolders/files that are older even if the root folder modify date has changed.
Wll
Re: CLI: Get subfolders/files that are older than x minutes even if root folder mod date has changed
Directory timestamps are not even considered for the synchronization. Only file timestamps.
What does it even mean when a directory timestamp changes?
Guest1970
Thanks for the Reply,
When I create either a subfile or subfolder under the root folder the time stamp of the root folder changes to the date/time of the lastest file/folder that was created.
Root folder:
drwxrws---+ 7 root Test 168 Dec 23 11:17 12-23-2015
Subfolders under 12-23-2015 folder
drwxrws---+ 2 root Test 48 Dec 23 10:00 test1
drwxrws---+ 2 root Test 48 Dec 23 10:00 test2
drwxrws---+ 2 root Test 48 Dec 23 11:17 Test3
If I run the script at 11:17, looking for files/folders modify time > 1 minute, I would expect folders test1 and test2 should be downloaded and not test3. No files are downloaded until the root folder's (/Data/Test) modify date > 1 minute.
script:
open sftp://user@server -privatekey=privatekey.ppk
lcd local path
cd /Data/Test
get *<5N localpath
close
Will
I made a mistake when I posted the script.
get *<5N localpath
should be
get *<1N localpath
Will
You want this
get * -filemask=*<1N localpath
It makes WinSCP recuse into all subdirectories (the *), but download only the files that are at least one minute old (the -filemask=*<1N).
