Create new WinSCPnet.Session Object in VBA fails
Hi I'd like to use your .Net wrapper to do some FTP-Stuff within MS Access 2010 with VBA.
As I try to create a new Session-Objekt, I allways get an Automation-Error ([-2146233321] Automatisierungsfehler).
I did download the latest Assembly and registered as written in your Website.
In Access the TLB is visible after registration and 'compiling' the VBA-Code went without errors
The Code which fails looks like this:
Is there something else I've probably missed to get the Wrapper running?
I use Windows 10 on a 64bit Dell-Maschine.
I appreciate your help
Kind regards
Hans
Sub SessionOpen() If Not mySession Is Nothing Then mySession.Dispose End If Set mySession = New WinSCPnet.Session On Error GoTo er mySession.Open GetSessionOptions GoTo finish er: handleError True finish: End Sub
Kind regards
Hans
