How to get SshHostKeyFingerprint to download files from FTP Path to local machine
Saravana
Bangalore
Hi Friends,
I have written code to copy files from FTP Path to Local path but I am unable to get SshHostKey. Kindly suggest me how to get host key. I used portable Winscp.exe to transfer files. Thanks in advance. :)
Thanks & Regards,
Saravana
ImNewToThis
But then what??
I have read the FAQ and found my hostkey through a ssh command prompt. What do I do with the key after I found it? How do I set it up correctly in the sessionoptions. It keeps returning an error.
Re: But then what??
I'm not sure what you are missing.
Set the SshHostKeyFingerprint property to the value of the fingerprint
(though I assume you know that part).
