WinSCP.com open site
Shellas Sahib
I am using winSCP.com on a script to connect from Windows to iSeries. I used the GUI and created a session with all configurtaion setup and username. I dont have a choice of saving a password and want to pass it to the script.
My issue is i want to know when i use the open command with the site, is there a way to pass the password? DAont prefer to use the open ftp:// command.
see below i am doing from command prompt:
winscp.com /script=E:\Command\ftpscript.txt
ftpscript.txt
option batch continue
open Test1
lcd E:\Input
Re: WinSCP.com open site
Did you specify the password on Login dialog, before you hit Save?
Yes we specified the password and it is not saving. even if it saves, our corporate policy wont allow saving password, unless WinSCP saves in as encrypted.
