Anonymous FTP synchronize
jmjones8
Fairbanks
I am trying to automate the synchronization of a remote file to a local file, and the remote file is on an ftp that I anonymously log into. I am trying the following script
option batch abort
open ftp://anonymous@ftpsite.edu
synchronize local "C:\\localfile\\" /remote/file/names
And it is not working. This is similar to something I use for sftp file transfers, which works fine. I can't find examples using an anonymous ftp, so I thought I'd ask here. Thanks.
Re: Anonymous FTP synchronize
The arguments of synchronize are paths to directory, not file.
You cannot synchronize files directly this way.
You can use a filemask to restrict directory synchronization to a single file.
But it's an overkill, why don't you just use get -neweronly?
get -neweronly /remote/path/filename.txt C:\localpath\
https://winscp.net/eng/docs/scriptcommand_get
jmjones8
Fairbanks
Hi Prikyl,
My apologies for not being too clear. I am not trying to get the newest files, I am trying to get about 300 files (about half the files in the folder) that are an archived data set that I want to download and process. I have used file masks to get similar files through an sftp. I edited the arguments for synchronize to only be the one of the directories with the files I am after, but no luck.
