Error in writing to the remote server
Hi I am getting this error when trying to transfer 'ship confirms' records to the commerce server. Can you clear up for me, which of these fix options to choose and how.
Error:WinSCP.SessionRemoteException: **Upload of file 'SC_Walmart.com_2011-07-31_16-08.txt' was successful, but error occurred while setting the permissions and/or timestamp.**
If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. ---> WinSCP.SessionRemoteException: General failure (server should provide error description).
Error code: 4
Error message from server: failed to set attributes: /Root/partner/incoming/confirms/walmart/SC_Walmart.com_2011-07-31_16-08.txt
--- End of inner exception stack trace ---
Error code: 4
